gnfirefighter
BLACK SHEEP
- Nov 16, 2001
I am restoring all of the trim on my 84 GN. It is light sand grey....I found a local distributor that will match the paint. Does anyone know the correct paint code for this car....Is it #13????
Dumb question ......... Do you know what the paint code is?84GNGary said:My code was 60I medium cognac (91), good luck finding it. GNfirefighter has the right idea by going to SEM. You will know that the paint is made for plastic, they will also have what you need for preping and priming so it sticks.
84GNGary said:See if these help. Maybe I misread the rpo code or the code decoder I found on the net is wrong. I always thought it was lightsand too. Since you are going to color match does the name really matter
Just went and checked the rpo code I have 60H & 60I, do not have 60C.
Jerryl said:Thanks for the pics.
I decided not to color match and repaint with the original color.
Should be a LOT easier to keep clean. :biggrin:
Honestly, I was unable to determine the color from the pictures.84GNGary said:So what color do you have and what is it's name & code ???
Is it the same as my car ?
