Well I picked up James's 85 GN as some of you already know. I have already begun purchasing stuff for it in full force lol.
I will start out by saying that I have no intentions of making this thing a show car, or anything close for that matter. I want a fun, good handling, FAST, GN with roughly 500whp that I can take out and not worry too much about getting chips in the paint
Here is a list of what was on the car to begin with
114,xxx miles, although engine, trans, suspension, brakes, etc are all rebuilt.
Sportsroof (moon roof/sun roof), G-80 Posi, Cruise, Power windows, etc all works. AC needs recharged. (Converted to 134)
Rebuilt Engine with less than 20k. I just did new intake, oil pan, and valve covers as it had a tiny leak.
STD/STD Turbo cross drilled crank
Double roller timing set
TRW Forged pistons .030 over
Stock rods, polished beams, shot peened, ARP bolts
Plasma moly rings
Edelbrock 204/214 cam and lifters
New Comp springs, retainers, keepers
Hardened rocker arm shafts with RJC rocker braces
Extreme ported big valve heads. Epoxied floors to smooth/direct airflow
Head cut to use Felpro 1007 lockwire head gaskets (and I do use them)
ARP head bolts
Stock upper plenum, modified w/ epoxy and an aluminum plate curved to direct airflow
New water pump installed with new motor, 160 degree thermostat, hoses, clamps, etc
Brand new gear reduction mini starter installed January 2013.
Transmission:
200R4 (4 speed auto) Rebuilt about 15k ago “Bullet Proof” By Chance & Sons Transmissions in Haysville, KS (of Neal Chance Racing Transmissions/ Converters) (cost almost $3,000!)
Neal Chance converter 3,000 stall
Billet servo, good bands, clutches, etc
AN fittings and lines from trans to cooler
Drain bung welded w/plug in pan
Temp sender bung welded in pan
Just completed trans service in August
Rear end:
Moser Axles with longer wheel studs
Moser C-Clip eliminators
S-10 Rear wheel cylinders
Aluminum brake drums
Big brake pads (all 4 long pads, not short and long, to hold boost better)
Brand new braided stainless brake lines front and rear
Brand New 85 GN Center caps ($200!)
Polyurethane Body mounts (w/ extra GNX location bushings)
Front end completely rebuilt with polyurethane bushings throughout, new tie rods, ball joints, etc
HR Parts-n-Stuff Poly motor mounts
Boxed stock rear control arms (upper and lower) w/ poly bushings
Poly Rear end bushings
Precision TE-44 turbo, (58mm) Jet hot/ polished
Always run through Turbo saver remote oil filter (2 filters, always run WIX)
RJC Biggie oil filter adapter
Front mount intercooler (Eastern Performance)
Aluminum bumper supports front and rear
3” Metal MAF pipe
K&N filter
Alky Control progressive methanol injection
Terry Houston 3” down pipe and test pipe (w/ cutout, or can install cat converter for smog)
60 pound/hr MotoTron injectors from TurboTweak
TurboTweak Chips (91, alky/ 91, E85)
Kirbans adjustable fuel pressure regulator
Hotwired 340 Walbro from Racetronix
Flexible rubber lines in rear replaced with AN fittings and hose, with inline cleanable fuel filter
Pypes Stainless steel dual exhaust 2 ½” Installed October 2012
Dual air bags in rear springs (independent air control for launch)
Line lock on switch panel in ash tray
Dual Ramchargers electric fans, switched at the ash tray
ALRADCO HID lights (amazing!!!)
Brand new Recaro bucket seats, recovered in GN fabric, with Turbo 6 embroidered (have stock seats if you want them too) Recaro's were about $1,200
3 3/4” Autometer Sportcomp tachometer
2 1/16” Stewart Warner Max Performance Oil pressure gauge in console pod
2 1/16” Autometer Sportcomp water temp gauge in console pod
2 1/16” Autometer Sportcomp boost gauge in A pillar pod
2 1/16” Caspers Knock gauge in A pillar pod
Pioneer CD player w/ flip down/removable faceplate, w/ipod input
Pioneer speakers in doors, hatch, etc.
New NOS shifter handle
New bumper fillers front and rear
Stay down fuel door
I will compose a list of what it needs and what I have done to it and update it as the build progresses.
Needs:
-carpet
-floor mats
-door pull handles installed
-various dings
-paint cut/buffed/waxed and fix rust in the doors
Stuff done so far:
-ordered carpet and floor mats from gbodyparts
-120# injectors ordered
-double pumper
-kit(255s) ordered
-tt chip, e85, 25psi ordered
-led tailights ordered
-window tint
-tires
-bilsteins
replaced the knock sensor, and autometer boost gauge with a vdo one that shows vacuum as well and an AEM wideband o2
I got a new Kenwood stereo and replaced all the old speakers
At that same time I got an alarm installed, it is a Code Alarm Pro Comp series.
Here is how it looks at the moment.
I know the carpet looks like poop but that will be swapped out as soon as I get my package from gbody parts
Plasma moly rings
ARP head bolts
Transmission:
Rear end:
3” Metal MAF pipe
K&N filter
Stay down fuel door
Needs:
-carpet
-floor mats
-various dings
Stuff done so far:
-double pumper
-kit(255s) ordered
-window tint
-tires
-bilsteins
