Depending in how much power you plan to introduce to it you might get by with a "tight" direct clutch setup and a larger 2nd servo, along with larger boost, rev boost and the 700 spring.
If you plan on really beating on it a billet shaft forward drum and dual feeding the direct might be in order.
