Tori
- Nov 4, 2013
Hey gang, alright...... as you know i've got a new to me GN. 1987.
I have a million questions and no one to really bounce the little things in my head off of.
I'd like to ask these here, not sure each one deserves it's own thread, feel free to pick and choose what you can/want to comment on.
Thanks !
1. Why air shocks ? I see them installed on car here on the site but wonder about the reasoning. I get it if your putting big meats on the rear and need the clearance. But why on a stock car ? Do the rear springs sag over 27 years ? I've never been impressed with the ride from an air shock, always seem bouncy, and these do on my car too. Thoughts ?
2. Is it just not possible to roll the windows up at speed ? I know i have issues to deal with regarding my windows as sometimes my driver one goes up on the inside of the rubber seal at the back, other times not.
3. How does the Power Master brake system work ? I've asked this in the "brake section" but not received an answer. My brakes are shit, (hard pedal) and i need to understand how this system is supposed to work so i can proceed with diagnosing it, and deciding if i want to keep it or switch to vac. booster.
4. Cruise Control: Mine doesn't work. Green light comes on, (only once set or resume is pressed - not when switch is turned on) but does not hold speed, or accel. What's the best way to go about diagnosing this ?
5. I need new wheels. All mine are bent. Should i just keep searching the classified section here on the site ? Suggestions ? I like the stockers, but wouldn't mind a set of the GNX look-a-likes.
6. When running down the HWY, should my Autometer boost gauge be showing boost ? Seems like it should be showing some. My Cummins shows 6# or so at HWY speeds.... ???
7. Anyone tried LED bulbs for the instrumentation lights. Most of my cluster warning lamps are out, along with the bulb in the headlight switch. Thought while i was at it, i'd replace them all, and maybe upgrade. Thoughts ?
8. Why are there two different horn buttons ? I have the Buick emblem, but i see the Turbo emblem too. What gives ?
9. Suggestions for speakers ? All mine are shit, and the rears have literally fallen apart on our trip from FL to CA. There was a pile of the foam surround laying in the trunk when we got home. WTF ! LOL
.... i know there will be more questions, and thank you for any input you can share.
Thanks !
