200R-4 Short shifting
TURBO2
Years back I bought a PATC Raptor 200R-4 to replace the transmission in my 1986 GN. Before I bought it I had asked them multiple times if this was an exact replacement with no modifications necessary and they said it was. After being installed the mechanic said that there was an extra wire with no where to hook it up (auto OD) so right away being manual OD this was NOT a direct fit. To make matters worse the transmission would short shift at only about 3500 - 4000 RPM under full throttle. Under part throttle it would shift through the gears and be in drive by 35 MPH. PATC sent me a new governor and it made no change. My mechanic also adjusted the TV cable which only made a minor improvement. Due to other problems with the car and health problems the car has sat with limited use. I'm trying to get it ready for this summer but I have no clue how to go about getting a new auto OD valve body and governor that will match up with PATC's set up. PATC has been no help saying they don't carry these valve bodies.
Do you still have the original trans for the car? Because what you need is the original BR code valve body and governor. If you have the original trans, your best bet is to get it rebuilt by a known knowledgeable builder and sell the PATC unit. Second best scenario if you don’t have the original core is to find a BR valve body and governor and swap it in to your patc trans. Sounds like you need the wiring and plug too but the wiring harness can be built and the plug is available new.
It’s short shifting because the valve land diameters in other valve bodies are different than the turbo Buick BR code and there’s not many easy ways around that. Some codes of valve bodies are worse than others and you wouldn’t necessarily have to have a BR if you have to go hunting valve bodies
I still have the original Transmission, but I doubt I can afford a performance rebuild. I guess I will have to try swapping out the original valve body and governor and see what happens. I'm not sure what the Raptor has for a shift kit in it, and before the original tranny blew a shift kit was put into it. Will there be problems with the two matching up?
If you’d like I can private message you my phone number and can help you when you decide to do the swap. Use the separator plate that’s already in the trans. In fact if you don’t tear the gasket you likely won’t need to drop the accumulators and plate at all. We can check a couple of the valves in the both valve bodies and get you set up. Also use the wiring and plug out of the BR code core.
Getting your original trans built properly and back in the car is still probably a better idea but I understand if the money isn’t there it isn’t there.
Where you located?
Also I’d remove and inspect the existing valve body in the raptor trans before I ever touched the core. Could have a goofy TV pressure setup that’s intended for v8 or God knows what and could be made much better without cannibalizing the valuable BR F code core you have
The two people closest to you are Dave Husek in New York and Brian Bisonette who I believe is in CT. Both are probably driving distance for you and either can build you a fine unit to handle your goals.
Dave’s username is Dave Husek and his company is turbo Buick performance and Brian’s username is Bison and his company is Bison’s performance
Well after years of being sidelined I'm back at getting it running again. I looked over all my work orders and info I have on it since new. It seems that it has ALWAYS short shifted since new. I see a complaint to the dealership, and also a note from Jack Cotton that it is short shifting, all when it was still stock. Changing over to the PATC transmission just seemed to add in the instant shift under light throttle of 1 2 3 by 35 mph. I decided to buy a solenoid for the overdrive to put it back to auto instead of manual overdrive (if the port was there and just plugged) and hook up the wire the mechanic stuck up inside and saying there was no place for it to hook up. I took the transmission pan off, and started investigating and found that it already is set up for auto overdrive. The more I looked around, the angrier I became. The mechanic should have stuck to something he knows, like drinking. He used one wire in a loop, like you would for an older transmission like a 350, and he didn't tuck one wire up out of the way, he cut 2 wires off at the connecter. I rewired the connecter and hooked it up according to a wiring diagram I found for the 200R4. It now shifts more like it should, and automatically kicks down from overdrive but it still seems to suffer from short shifting. It is shifting at about 4,500 rpm under full throttle which still seems low, but better than before where it could be as early as 3,500 - 4,000 rpm.
I agree with Sam, give Dave a call.
I would also avoid going WOT with the car unless you have verified line pressure, would suck to smoke the transmission. Is the TV cable the original OEM unit and is it adjusted correctly?
No, it's been replaced, but still the same set up. With it at full throttle, the arm inside the transmission is bottomed out.
