Just installed the Denso Supra pump last night - I should have done this sooner!
Ever since I had the walbro the o2's would start to lean out when making a run. It could keep up fine if I was just putting around town or on the highway. My Walbro is not one of the recalled models.
Now the O2's are rock solid, and after install the base fuel pressure (line off) went from 43 to 50 psi. Time to turn up the wick and make some power! Also, seems to be working just fine on E85.:biggrin:
Anyone want a Walbro 169 pump with a date code of 15807? Pay shipping and its yours!
P.S. yes, I know O2's are a poor way to tune. Wideband O2 is on the way!
Might be interested in this, I live only 45 minutes away..
My denso failed on me after a few months. But I am the one who hooked it up backwards, just assumed the bigger post was positive. But it was negative. So it ran backwards for 6 or 7 attempts when trying to start. I also noticed that my fuel sock was bent upwards at an almost 90 degree angle. And one of the connections from the pump to the bulkhead was a little fried. First; props to silverturbo (ebay vendor) who sent me out a pump he had in stock with less than an hour on it from transferring some fuel. He said to send the other in and denso will warranty it if it has failed. Second, I am glad I ordered the g7 bulkhead wiring kit from Racetronix so I can get some good wire and connections. Only problem is that there are no instructions with it. Again I assumed I could figure it out. The snap fitting that holds the bulkhead connector in place goes on the opposite way than the stock one does. (figured that out after I put it on) I guess I'll try to wire the connection in place. Who can tell me what the "extra" black wire is for? One on the pump, 2nd to the hose clamp on the metal part of harness for ground. Third one,????? has a plastic connect end. Also what do I do with the ground on top of the bulkhead? I sent an email to Racetronix yesterday but haven't heard anything yet.
Still no response to my emai (Racetronix)l. Please get back to me. mike84gn@hotmail.com
Is there anyone else who could help on the g7 wiring kit??
can someone help me out with the racetronix wiring please
Looking at Ractronix kits, they say they include a Walbro pump, but I thought this was all about the Denso????
