Just because someone does it, doesn't mean it is safe or the best way. The reason little difference was observed is that no larger tire was required in the first place. That tire on a 10" wheel would provide a better footprint, but the car may actually lose a mph or two due to the additional weight. Ideally, you want the smallest tire and wheel combo for the lowest weight to get the job done. I've gone low 9s on a 18.5x31 and done the same thing on a 10" tire. The 18.5s actually cost me 2 MPH due to the additional weight , but the same ET. No way I would run a 325 on an 8" rim. While it is possible, it is not the way to go. Besides that, the manufacturer recommends a 9-12" wheel. 8 is a no no.
