dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
Just wanted to share some of the oiling mods I have performed on my production 4.1 block . First with the block I enlarged the feed passage to 1/2” . After doing this you will have to enlarge the turbo feed outlet to a 3/8” npt . After opening that up I went in and radiussed all the corners so they would be somewhat smooth instead of the 90* sharp turns they are stock . After that I went to the timing cover and enlarged the oil supply passage to 1/2” aswell as knocked Down those 90* turns . After all these mods it should help with the volume of oil going to my mains aswell as the actual flow . Here are some pictures
