paul, fuel pressure reg are they adj and need for stock fuel rail. hot wire kit in good cond ? drive shaft loop one pc ?do you have any cut out pipes where cat goes ?
thanks mike s
I will take the adj fuel pressure reg for stock rail, I will take hot wire kit and the drive shaft loop[ is this bolt in ]
thanks mike skwarlo send me your pay pal info again and total thanks
Do you still have the RobbMc billet sender and if so could you please send me a picture of it? Thanks
I saw that picture on their website to just trying to get an idea of exactly what it looks like with fittings on the ends. I was thinking it would have had male AN fittings silver soldered on it. I'm using- 10AN feed line and -8 return
