87turbot-type
wo2
- Sep 2, 2007
Finally got to the dyno today.
Very happy with the results. Car made 490.2 HP and 556.6 TRQ on straight pump gas 18psi through the run.
Combo is a girdled 233, un-ported gn1's, fast xfi with xim and LS coil packs. Turbo is a little 6131DBB, convertor 10" 2800 ptc 210-215 roller. 1.55 ratio. 3" DP 4" single (RJC) 80lbs, FMIC. T-netics RG45 WG (plumed to the turbo hole)
Because of the WG 8 psi spring this is the most boost I could get out of it and it seemed that this is around the max hp I could get on straight pump gas.
Will post pics and hopefully get the video up soon.
Brandon!
Brandon!
