Thats what the boostgauge read with new line. your buddy have a 6768dbb billet turbo with H cover ?
guess we will have to see what the other 2 6768dbb billet TR's run when they go to the track ?
I checked the boost on the return road after i weighed it with a buddy in the car . If the gauge is wrong its wrong. I have no reason to lie this is all on stock stuff if i had a logger on the car i could give more info.
Car is just like i drove it an u seen it in Charlotte with a diff turbo
Buy 1 an see Im not a TR tuner never claimed to be. This engine has alot of passes @ 27 psi and i know the heads have lifted acouple times never blown until saturday
That's because your boost was probably over 30psi. Seriously....you need to check your gauge.
I can vouch for the boost gauge as I was the one in the car on the return road. Read a steady 18 PSI. The gauge and line are brand new. There are no kinks in the line. There is also a manual boost controller on the car that probably only has about 5-6 full turns (1 turn = 1 lbs.) on it from no tension. The actuator is set to 13 PSI.
I'm not saying the gauge is right either, just saying that this is how everything is setup.
Grumpy said:.....snip..... Oh .. internal wastegates don't work ??
I didn't say they didn't work across the board.... let me clarify.....I said there are several people that have found after swapping to these new billet wheel turbos.... 62mm and 67mm...... that they found they now have major boost control issues.... lots of boost creep......where they didn't have any before the swap....... do a search Grumpy..... :wink:
Scott
I don't mean any disrespect here but i don't believe you ran a high 10 @ 18psi of boost.
I have been around a bunch of fast GN's and none has ever ran that fast @18psi on stock heads.
my buddy had a t with a te-45a FMIC 32k 9/11 and he ran a 6.97 @ 100 mph in the 1/8 @ 30++++++ psi of boost.
his name was greyghost on here.
