JZ 97 SS 1500 said:76mm unit is long shaft only.
You have either a 70 or 74mm unit.
Jose
Trbobuick said:Well,
It also appears the 76 has the smooth bore on the inlet. I have the step down bore in picture 1.
Compressor housing bore is just under 75 MM. Goddamit.
John Wilde said:So what are trying to say is that he has a short shaft!!??
JZ 97 SS 1500 said:Lol, sounds like he got the shaft....
top gun said:Brian, I thought you were sold a 42/76, which vendor did you purchase it from?
KLHAMMETT said:I believe there is a 100hp difference
Trbobuick said:Vendor just called. We are working it out.
KLHAMMETT said:nope
I may be wrong so correct me if i am
4202 (which i think is the 74) rated at 1100
4276 rated at 1200
Again i may be wrong but i believe this is correct
