HelloBozos
A Bozo in Buick
- Feb 9, 2011
This may be a long shot, but since it sounds like you have good fire, the only other thing left in the equation seems to be fuel. Have you entertained the thought that the fuel pump could be overheating and giving up the ghost, and not allowing a restart until it cools back down????
After one of these stall sessions, does the pump re-prime with key on? And if it does re-prime does the car still refuse to start?
Yeap,tried it, Full fuel pressure,no bouncing needle starting,I've read about the fuel starving issues (wiring,old pumps,relays tanks not grounded)I'm running a 5 year old but only 4000mileof total use reds single xp pump hotwired,I only have good firing patteren till the issue happens, this is more the End of the correct spark/firing patteren,an what's wierd, when it cools back down ,it's correct again...lol..but when it happens it's Imedeant,even if held at 2500rpm...in less then .001 second, no fire...
