87 GN Rust free frame
boostjunkie
NEED MORE BOOST
This is a correct 1987 dated GN frame for a turbo Buick with the HS code with no accident damage. This Frame is unique to the 86 87 Turbo Buick cars only .
o
if somebody tells you that any G-Body frame is the same they are wrong. $750 located in Pittsburgh PA
May i ask what the difference in the frame is? I was not aware of this. Good luck with sale.
Sent from my SM-N960U using Tapatalk
The 86 87 Turbo Buick frame comes from the factory with a larger rear crossmember
here is photo of a 87 NA regal rear crossmember
here is a correct 86 87 Turbo crossmember it uses a much larger brace
take a good look at the rear brake hose location in each pic to give you a idea in the sizes
This is a correct 1987 dated GN frame for a turbo Buick with the HS code with no accident damage. This Frame is unique to the 86 87 Turbo Buick cars only .View attachment 333969 oView attachment 333970View attachment 333971 if somebody tells you that any G-Body frame is the same they are wrong. $750 located in Pittsburgh PA
here is photo of a 87 NA regal rear crossmember View attachment 333980
here is a correct 86 87 Turbo crossmember it uses a much larger brace View attachment 333981
I think they is more to it here is a picture of my frame on my Gn but I know my frame has been replaced on mine it is an 82 frame
Would help if I loaded pictures. I know it’s a 82 from the date code
the 81 frame has no Provisions for Overdrive transmission crossmember mount also the rear frame rails have large oval shape holes stamped in it in front of the rear wheels un like a 86 87 frame and the rear crossmember shown in your picture is not the same as a turbo Buick but more importantly a correct 86 87 turbo car frame carries the HS stamping quick and easy to be seen from under the car
BoostJunkie has owned, worked on, torn down, repaired, parted out, or restored enough of these cars to know details that only a very small amount of Turbo Buick experts could answer.
The knowledge that he has isn’t about colors or production numbers....it’s about the authentic parts and options.
Trust what he says.
