http://www.aempower.com/ems.htm#
Seems AEM has or is releasing a programmable EFI too. Things I noted in the specs (that I've only breezed over) are dual O2s, wideband capability, and user programmable inputs and OUTPUTS
That last is a doozy - boost control anyone? Wheel slip logging? First I've seen of this thing, anyone have any information on it?
More detail - seems boost control and electronic trans control are already included. Will do up to 10 cylinders, has waste spark and DIS controls, and on and on. Hmm!
Outputs
10 Injector outputs
5 Ignition outputs
1 Fuel pump output
4 +12v User defined drivers (VTEC, EGR, etc) outputs
2 O2 Heater ground controls
2 Temperature controlled outputs (radiator fan etc.)
6 user defined (-) switched outputs (NOS, a/c, purge, etc..)
1 Check engine / shift light
1 Tachometer output
2 PWM outputs (may also be run as switched outputs) boost control, IAC motor, staged nitrous, etc)
2 Stepper motor drives (may also drive 4 wire antagonistic pair outputs)
Inputs
2 Knock channels with control
2 O2 channels with control
4 Thermo couple inputs
6 Gear position inputs
5 Speed sensor inputs
1 Spare temperature input
Throttle position
Manifold pressure / Mass air input
Barometric pressure sensor
2 Spare 0-5v input (pressure sensor, or position sensor)
Coolant sensor
Air inlet temperature
Battery voltage sensing
Clutch or neutral input (may be used for 2-step rev control)
Crank position (timed)
Cam position (timed)
Extra TDC or air flow (Vortex) input
Speed sensor input (for gear selection, traction control, etc)
Filtered sensor ground
Memory
1 Megabyte internal logging memory
Flash ROM
Fault logging
Communication
RS-232 pc com link
CAN high speed bus
High read write duty
Outputs
10 Injector outputs
5 Ignition outputs
1 Fuel pump output
1 Tachometer output
Inputs
Throttle position
Coolant sensor
Memory
Flash ROM
Fault logging
Communication
RS-232 pc com link
CAN high speed bus
