Its Not That Bad Of A Job,first Of All If Your Interior Is Still In The Car Cover It With A Sheet ,pull As Much Of The Old Strip Out That You Can I Used A Wire Wheel On A Drill To Get It Real Clean.but I Was In Process Of Painting Whole Car ,get All The Old Adhesive Out For Best Fitment ,i Got My Seals From Metro Moulded Parts (they Are A Little Fatter And Seal Real Nice ,but The T Top Glass Is Tough To Get Back In At First, But They Do Fit Nice , Also Comes With A 15 Year Warranty.)i Also Chromed My L Shaped Brackets And The Center Bow (i Tried Powdercoating But It Destroyed The Center Bow ,so Chroming It Was The Best Protection From Rust And They Also Look Awesome With The Tops Off)i Then Covered The Center Part That Sticks Out With The Glass In With A Piece Of Black Vinyl Pinstripe.changing The Seals Is Time Consuming But Its Not That Bad At All Good Luck
