Blind combo setup
87-WE4
I'm courious to see what you all think I should be running with my current setup in the 1/4 mile.
Use scan master for tuning
60lbs flow matched injectors
Boost controller
Open K&N
Turbo tweak chip tuned for 25 psi boost
TE 60 turbo 25 psi
3 inch THDP
Hemco 62mm plenum
Alkycontrol methanol injection
Super extreme GN1 front mount IC
LT1 MAF with translator
Comp cam 980 valve springs
Fuel pump hot wire kit
Hooker 2.5 inch exhaust
Art Carr 3200 stall non lockup converter
Stage right transbrake leave around 7 or 8 psi
Fresh built transmission with billet drum
Rear air bag with 15 lb pass side
9 inch Mickey Thompson ET slicks
it ran a 11.54 @114 I think it has more in it maybe 11.30 just courious what some of you all thought.
It seems to drop off a little after 1/8
nice 60ft!the 1/8 to 1/4 gains are near typical of a stock headed car.if you want to go faster the car should pickup some with more boost as long as the converter isn't slipping it away or you could leave it alone and enjoy it;)
Was going to try maybe a pound more boost add little fuel cause at 10% added in the TT chip I'm hitting 777 on O2 and add more timing and maybe push it into the 11.30's
i would just add wot fuel with a few lbs and see if the car responds.timing is the last thing i would touch, if anything i would take out a degree or 2 while trying to get more boost into the motor.
Thanks for advice
