Kid Turbine
- Jul 17, 2007
Well car didn't sell so its Buick part sell now to fund the LS2!!!
stock 109 block $300
stock gm heads $150
stock turbo crank $150
stock turbo rods $120
stock valve covers $40
stock front cover $60
stock oil pan $20
Or can be bought complete for $750 already on crate for shipping also!!!
MSD DIS-4 with interface $500
Accel DFI6 ecm and adapter harness $300
(2) stock incoolers $75 each
(2) gn stock turbos $150 together
some misc brackets ?
Okay now for the built engine setup!!!
4.1 non stage block 257 c.i. motor (torqueplate bored and linehoned) $450
Jack Cotton CPT-61 Turbo $750
stock manifold rebraced and welded $100
custom turbo filtering system $100
Sealed power Hyper pistons (4.005") 8.7:1 comp. $150
Reconditioned 2 dot rods $200
Reconditioned 10/10 Turbo crank $200
Upgraded GN Heads with LT1 springs $175
Felpro 1000 head gaskets (free with heads)
MSD 50lb injectors $300
Stock balancer $40
Stock flywheel $40
Stock oil pan $20
Stock coil, wires and module (new) $100
Stock upper and lower intake with Phelum Power plate and fuel rails and ing. bracket and throttle body $400
Comp Cams 212/212 camshaft and lifters $100
stock ecm with Turbo Tweak chip for build $150
Front mounted intercooler $200
in car now running but before part out big items have to sell first or buy complete for $2500
If buy either complete engine I will work with you also!!!!
stock gm heads $150
stock oil pan $20
Stock balancer $40
Stock flywheel $40
Stock oil pan $20
