GMTECH12002
- Dec 1, 2004
Yes 25 psi is too much, 20 is too much, you probably have a waste gate stuck closed on the turbo, you will lean out badly at these boost levels and loose the head gaskets or worse. Manually operate the waste gate by hand to make sure it moves, also make sure your vac/boost lines are intact and hooked up correctly. Don't run this car at wot with this much boost, you will have serious failures.
