TurboSlacker
SINISTR
- May 29, 2001
Dennis,
Give us your tips on how to get a turbo V6 to idle and run smoothly.
I've tried many things to try and smooth out my rough idle and even a little roughness at rpm's above idle:
Ignition coil pack & module
Plug wires
Spark plugs
PCV valve
Downpipe clear of frame
MAF swap
Ran engine without accessories, i.e. serpentine belt off, still rough
Disconnected CAM sensor connector while engine running to put it in batch mode - still rough
Lifter preload – shimmed both rocker arms
GM top engine cleaner
ECM
Other ideas I had are:
Motor mounts
Head gasket
Head valve not sealing
Piston ring
Torque converter
All my Scanmaster numbers look great and the car runs strong. Vacuum is steady at 16. The engine rocks back and forth more than most turbo V6's that I've checked out.
What else should I troubleshoot or test before ripping the heads off?
Plug wires
Spark plugs
PCV valve
MAF swap
ECM
Motor mounts
Head gasket
Piston ring
Torque converter
