I have a stock 85 t. Going in are the following :
Ta33c
42.5 lb injectors
Walbro 340
Adjustable fuel pressure regulator
150a power master alt
Fuel hotwire kit
Caspers fuel injector harness
Caspers alternator harness
Newish timing cover with high flow oil pump and new water pump
Egr block off
Related tt chip
Now would be the perfect time to do the cam. Should i? Looking at the comp cams flat tappet 69-248-4. The old cam was fine stock. Will I be leaving alot on the table if I don't change it?
Thanks, Rick
Ta33c
42.5 lb injectors
Walbro 340
Fuel hotwire kit
Egr block off
Related tt chip
Thanks, Rick
