TurboTerry87gn
- Mar 3, 2003
I just can't get this thing to hook at the track and I'm tired of wasting money.
All this is with a TH400 on the transbrake.
Sock suspension I went 1.6 sixty foots on 275 BFG drag radials no front sway bar, and air bags adjusted to many diffrent settings for each combination listed here after, KYB shocks, I heat the tires a little, I heat them alot...
Put welds on and 28 x 11.5 x 15 et streets and still cut 1.6 sec 60's
Put Edelbrock upper adj. control arms to adj pinion angle. same
Put on metco lower control arms same, added the instant center brackets that came with the arms, same 60 foot time
Put on compitition engineering rear drag springs and front drag springs same 60 foot. Put on front drag shocks set at 90/10 70/30 60/40 still using kyb's in rear.
Took off the comp. engineering front springs as the driver side spring collapsed over time.
Now I'm thinking about adjustable rear shocks and a wolfe racecraft rear sway bar. I talked to another buick guy at the track that suggested running stiffer sidewall slicks, but I'm going to notch the frame and use the 325 MT drag radials now.
I can leave at about 10 lbs any more I just blow the tires away. 6.7's in the 1/8 at 103mph with 1.6 sixty foots....just want low 1.5 would like 1.4's
