Wanna hook, PM "SPOT MY 6" without quotes.
Heres his car:
Videos > Best 60 time - 1.299!!! - FQuick.com
1.299 60' !!!
Heres his car:
1.299 60' !!!
Stock rear springs (cut slightly to lower the instant center. Rear of car was lowered 1.5") (free)
SPOT MY 6,
I am curious how you cut the rear springs with them being "pigtailed" on both ends. I have been considering lowering the rear of my car also to try and achieve the lower contol arms being level.
Thanks,
Robert
SPOT MY 6,
Thanks,
Robert
I cut very small sections (1/8 coil) off the top of the coil at a time with an air powered cut off wheel. I made the cut on an angle so that the spring would sit somewhat flat inside the spring pocket. Then I went to pep boys and bought some rubber heater hose that slid over the end of the coil so that there was some cushion between the spring and the pocket.
Ok I have achived a 1.501 60' but of coarse I want more.
I'm going to stiffen the rear shocks next time out. They are set at 4 click now. Looking at the videos the car is squating alot. I might even throw the IC brackets back in to see what happens. Also the video shows the driver side tire making a complete revolution before the car starts following along. For the first revolution the car only moves about 6 inches.
Next on my list to try an MSD DIS-4 HO. I know I said I would never put a JUNK MSD box on my car, but my friend has one he is going to send in for repair off his supra that I can use(free!). We will see if it helps with my high load intermittant miss and 60' times using the 2 step.
I'm hoping I can find the sweet spot in the power band to get the 60' times down and more consistant.
Did you completely miss my post? You PM'd me asking for help so I gave it to you. Stop wasting time and money until your pinion angle is set. Or, just ignore me and Ill keep doing big wheelies in the low 1.3's while you struggle to get into the 1.4's.
