- May 26, 2001
Everyone here loves pictures, so if you do not want to believe Brian, Neal or Kenny, here are 6 plugs removed Friday from a 10 sec. GN and the ones from no. 1 and 2 cylinders should be obvious with ground electrodes about gone, and the center electrodes and porcelain almost gone.
The tune was fine and has been for a long while, BUT, this time Autolite 103 street plugs were installed instead of race plugs.
Big mistake to use projected tip plugs in a low 10 sec. or any high boost build.
This car does run a stock fuel rail.
On my race car that is fed with 2 -8 lines up front and 2 -8 returns on the rear, plugs no. 3 & 4 did run lean, but Cal has compensated for that with his tune in the XFI.
