Here is an updated list of whats available I will be posting more items within a couple days, if a part is not listed here that your looking for please feel free to ask. I am open to resonable offers.
Stock wheels with centers in Very Good Condition 400.00
A/C Compressor (needs clutch) 50.00
Stock 87 reciever/dryer 15.00
Stock rear sway bar 15.00
Stock Intercooler 100.00
Stock Electric Fan 25.00
Aftermarket hayden single electric fan 25.00
Stock air cleaner housing and bracket with K&N filter 30.00
4" X 14" K & N filter 25.00
Plastic covers for under the dash 15.00 each piece
Stock rear springs 20.00
Stock spindles 35.00
cowel with screen for 1965 Buick Lesabre 30.00
Set of Black Steel Wheels with factory Buick wire hub caps 150.00
4 X 10 Kicker Speakers 50.00 for pair
Stock front Door Speakers from Concert II System 15.00 for pair
Front Right Turn Signal in Bumper (small crack in lense corner but keeps moisture out) 10.00
Front Left Turn Signal in Bumper (small cracks in lense but keeps moisture out) 10.00
Turbo Nose Extension 10.00
Stock Front Dash Speakers Concert II System 20.00
Stock Fuel Pump with only 40,000 miles on it 15.00
Computer Access Cover 5.00
Stock Vacuum Block 10.00
Stock Turbo Cover (modified to fit stock DP through 3 1/2" DP) 20.00
Stock Coolant Resivior 20.00
Bracket 1 10.00
Rubber Splashgaurd Set 10.00
Stock Torque Converter (pulled when front pump went out) 75.00
Air Dam 10.00
Early V8 stock Coil Bracket (round blaster 2 style coil) 5.00
GN Ashtray 5.00
Spare Tire Retainer 10.00
NEW Rubber Valve Cover gaskets ( fel pro VS39763R) 10.00
Bracket 2 10.00
Screen 5.00
NEW GM Shift Cable part # 25537476 45.00
Battery Brace/Bracket (core support to Body) 10.00
Complete Prom Chip burner, eraser etc (to burn GN chips) 225.00
Metal crankcase Breather 5.00
Mass air flow screen and retainer 5.00
Stock Fuel rail Schrader Cap 5.00
Bracket 3 5.00
Stock used Camshaft (no visible wear) 45.00
Pics are available of any items just ask
**The pics of the brackets go in order they were posted**
