Complete double pumper kit (225$ shipped) SOLD
evil666
Comes with 2 walbro 255LPH Fuel Pumps
Adjustable hub switch that is boost activated.
Sending unit with all the wires needed with relay to make this kit a complete bolt on.
The 2 fuel socks are in good shape and clean and could be reused without a problem.
275$ shipped
When I ran at the track the last time , I ran it on E85 with these pumps and they worked very well. Was told to upgrade to the racetronix double pumper that is E85 compatible. That kit was not cheap, payed 800$ plus shipping. I put back pump fuel in the tank and the car was stored with pump fuel cause they say that is not good to store a car on E85 over the winter. Now I run the racetronix double pumper and the bigger Teflon fuel lines from racetronix . All I could say is yes it works with E85, but the pumps are not E85 compatible. As long as you don't leave the pumps sitting in E85 for the whole winter , I think it should be fine. Really don't know how bad it is to run E85 fuel with pumps that are not E85 compatible and that is why I upgraded to the Racetronix set up.
