need to look at the weight of the car,but the mph does look soft.Had the boost up around 27 psi all I had balls for 11.36 at 117 mph with a 28" tire.
60ft does need to come down, looking at the 1/8 to 1/4 mile gains will show if the car is laying backhalf targets should be around 25mph.need to get the weight of the car thoughGot my 60' down to a 1.60 that still needs work, i left with 7lbs of of boost.
you will break less at 11.49My first quest was for 11.49 now it's a 10.99
Don't have logs, this is what Turbonetics told me, has as much flow rate as a 70mm, I cant prove or dis-prove.Post up some logs. 90lbs/min with a 64mm inducer on one of these isn't anywhere near typical. Even 80lbs/min is rare.
well im not going to show anyone my logs but i will say i have a tnetics hpc 64 that's makes that kind of power and im not the only one who has hit 800+ with one either.Don't have logs, this is what Turbonetics told me, has as much flow rate as a 70mm, I cant prove or dis-prove.
it depends on which ex wheel/ex housing you would use,i used a ptc 9.5 nonlock to spool both a 65 and 68 ex wheel.How much converter would a guy need for the bb version.
I think its only avail in BB version.How much converter would a guy need for the bb version. My 61 spool real quick
Well I would probably stick with the .63 and 65 wheel it's fun on the street.
Hi,
jmho,
I agree with the 65 turbine wheel...or more.
A TRUE(.63 ) Garrett or Tnetics is a 400-500hp a/r exhaust housing unless it's the bigger PTE .63 (which is largest out of the .63 advertised housings)
Don't see the point of putting that high flow compressor with that small (honda like) exhaust housing.
Tnetics .82 would be a better fit for a high flow 64(65)imo.
