Well, I was convinced that I had blown a gasket into the intake valley in my WE4 racing last Wed., but I'm beginning to wonder.
Ran up to 28 psi boost on alky and pump gas in tuning runs the night before and it felt great! No KR! BUT, it was smoking a little when I pulled into the garage. No big deal, I thought, just oil dripping on the crossover as usual.
Pulled it out of the garage to race Wed. and there was a slight miss... BUT, I had just tested the alky pump twice so I knew there was some sitting in the motor in puddles. Sure enough, it cleared up.
Ran a first pass at about 25 psi (12.33@112.89) and I was thinking "not too bad for the first pass of the year, and it was 10 degrees hotter than the day of it's best pass last year not to mention pretty damn humid out." O2s looked good on TLink (.810-.830) and 1.2* KR. I noticed some oil on the plug wires from the dip stick tube, which I had never seen. Oh well, I came to race!
I upped the boost 1 psi and fuel pressure about 4 psi and made another run. 26 psi... half track there were two loud "pops" so I backed out of it. TLink showed some lean frames (low .700s and about 9* KR)? May have pushed my fuel pump too far. After determining that there was NO antifreeze in the oil, I drove it home gently (in the rain) and it ran fine. Just started it up and it still smokes a little out of the pipes, but not much and doesn't look/smell like oil really. If I remember right, it was smoking a very minute amount from the pipes before all this, but the oil out of the dip stick tube has never happened.
Any ideas? Thanks,
Any ideas? Thanks,
