Evans Ward
Love those LC2/ Y56 cars!
- May 24, 2001
Helping a friend work on his digital dash on his '85 GN. He has an intermittent cutting in and out on display of his MPH speedo reading. Other features work as intended on the read out. My question is regarding the black plug that the digital dash plugs into. This the the plug that comes throught the blue green circuit board piece that the tin plated ears from the module connect at. Should the black connector have two lock/ locator tabs at both the 12 and 6 o'clock positions to center it outward and level? Asking that as my friend's car only has the lower 6 o'clock lock tab present/ intact . We cleaned the fingers on the tin plated parts with a pencil eraser and did the same for the rear of the printed circuit board (after removal) with the copper contact areas. Used compressed air to blow out all the connectors too. Car still has the same problem after what we did and I'm wondering if he may have a bad VSS buffer? Next question is how to test for that? Thanks!
