i know a lot of people run a mix of e85 and 87 or 91 octane anyway... usually around 50/50, on their e85 chip.
I have the same issue as you (except maybe worse)... there is only one e85 station where i live. I figure I'll put as much e85 as i can get in there when i fill up, and then if i have to dilute it a little bit with gasoline, its no big deal -- I'll just fill it up with 87 when my tank of e85 is halfway empty, and keep boost where it won't knock, even with a mix. Actually, since I only have 60 lb. injectors, I can probably only get away with 25 psi anyway before i start maxing them out.
Anyway, with a 50/50 mix, you apparently get almost as good mileage as with 100% gasoline, so that should be enough to get me where I'm going and back again, when I head out of town. And i always have my old 91 octane chip if i ever run out and have to put 100% gasoline in there. I'll just have to write down my custom tune settings on my e85 chip so i can adjust it right back when i put it back in.
so dual chips sounds like a good backup, but since a lot of people run a mix anyway, you probably wouldn't be forced to use it very often.
I'm hoping e85 gets a little more widespread around here though... i heard that maybe Murphy's (the wal mart gas station) is going to start putting pumps at all their locations? anybody else hear this?
