- Nov 4, 2005
put two pumps back in the tank,and found a e85 gas staion 40 miles away. filled her up ($2.09 gal ) turned fuel pressure up and started home....my coil pack is weak,when boost comes in its cutting out (i put the ORIGINAL pack back on just for a car show).
so tomorrow ill put on my msd wires back on and a new pack on and test again.not running the right chip (TT gas)or injectors(42's) but, the butt dyno even at 14psi is great.....and no knock untill the coil pack acts up.......
will look for 11 on the wide band and safely play around some tomorrow.
