Motions9985
- Jun 2, 2002
Replaced timing chain and heads. Engine has no spark or fuel injector firing. Also since car would not start I have replaced cam sensor, crank sensor and ignition module. I have also performed all troubleshooting . All voltages and grounds OK. Scan tool gives readings on the engine sensors. Can the ECM be bad, car was running good before tear down. Need some ideas.
