You guys are awful demanding:biggrin: Donnie here is some data that you can look at and determine what you want to from it. The throttle was told to open about .2 before the brake released. The following shows info including boost at .2 increments starting at .000 Mike![]()
Dusty, what kind of torque multiplication factor do you think we're working with here? Right now I'm using 1.7.
At release of the brake.At what point of the run? We still talking the 1st 200 feet?
Torque multiplication is one parameter. TC slip is another. Although, the torque multiplication will affect TC slip.I'm probably fixing to show my ignorance....... but is the torque multiplication basically the number of engine RPM divided by the number of trans input shaft RPM?
so... the more slip.... the more theoretical "torque" you are multiplying?
Are you stepping the power in? I think I see 2 steps.
OK. I understand. Dang! Back to the drawing board.Yea Im stepping the power in!! It goes from idle to WFO in about .1 seconds!
Now thats stepping in the power!!:biggrin:
Mike
Mike, how long does it take for that air cylinder to go to WOT at the launch? I'm sure it doesn't just slap open.
The reason I ask is because for me to get the sim to match your rpm rise at the launch, I have to input a gradual ramp up of power. Between .5 to .7 sec.
I just checked my log book and for some reason I didnt log what I had the SLE (starting line enhancer0 timer set at. Im fairly sure it was at .2 before the brake release. As you can see in the last pics I posted at .000 (brake release) I believe it had 26# of boost and climbing rapidly. I would say that it is WOT at the start. Doesnt sound like thats what you want to hear , but there it is!! Mike
I knew it shifted pretty early but 173' ??? That sucks!!!
Both Donnie and I are both thinking this actually happens sooner.... like 151'.![]()
And G-force.
edit: Correction to your tire slip numbers. 18, 6, and 3. I also increased the torque multiplier for the TC by .05. That got me right on a 3.4 G at the hit. 156' at the 1.688 sec mark, with the 1.8 gear. 204' at the 2.016 sec mark and 8040 rpm with the 1.69 gear.
I have the G-force at 1.88 at 1.7 sec and 1.22 at 2.2 sec. It may not match the datalog, but it shows that the G-force does ramp down throughout the run. The ramp is shallower as the run progresses.I'm still playing a little bit.
When I plot the actual acceleration over time..... it flattens way out past the .6 - .65 sec.
I could assume that for at least say 1/2 a sec on out past the 1.7 sec......that the acceleration rate isn't too much different than at the 1.705 mark.
This assumption will allow me to make an educated guess how long it will take to get to 129 mph (when you change tranny gearsets) vs the 1.7 sec to get to 121 mph. That should lead me to how much distance it will take as well.
