Any reason to try and use the F-body bracket with the F-body bushings? I saw they are NLA, but I have the ones that came w/my sway bar used off the WS6. Do they not fit? I apologize for not knowing, but my GN is in another state and I'm gathering the parts now. Was able to pick up a 36MM bar off an 89 GTA for $25--but I don't want to put it on if this isn't a good idea. Right now, it seems that the 36 MM bushings w/G-body brackets should work fine..but are the F-body brackets better or worse?
Thx
I run the hollow 36mm sway bar on both the GN and the elky, I put poly bushings on the GN, but still using the GTAs stock bushings on the elky, but have poly endlinks on both. So far I haven't had any problems with either one. <knocking on wood>
