All this assuming the boost and fuel pressure guages are accurate. Regardless they should still be 1:1. Ive seen a lot of $hitty boost guages.Blazer406 said:No..... you have gotten confused....
Line off is 0 psi..... which is 43.....
Line on...idling.... is actually sucking on the diaphram....instead of pressurizing the diaphram (which adds 1 lb FP to 1 lb boost) .. the vacuum has the opposite effect of boost on the fuel pressure... so when you plug the line up.... it lowers the FP...... again... this is vacuum which is not the same as 0 psi boost..... soooooooo .... if you were going to 24 psi boost...... you would need (as compared to 0 boost) 24 additional psi in fuel pressure just to keep up.....
so 43 (line off) +24 = 67 psi fuel pressure .......
HTH
