Hey Guys
Trying to find a replacement for my wideband sensor
NTK LHA LZA 08-H6 but when I search it looks like the part # is 24302. Is that the right one?
no , if its in there and connected its functional but wouldnt hurt to look at what AF youre getting with a scanmaster 3, SMG xfi , edash , touch logger or a laptop
My original xfi instructions had a handout that said if you replace it
Select view...system configuration...wideband 02 type. Says it must be done each time a sensor is changed
if you "changed" to an older style (L1H1 L2H2) youd have to change the sensor type for that , yours is what you had and should already be selected for the LZA 08 H6 sensor (theres only two choices) .. connect a laptop and see wht is selected
