I have a customer with a '95 240sx that we put a FAST batch wb O2 ecu onto last weekend. Engine is a 2.4L DOHC 4 banger straight out of the boneyard for a couple hundred bucks. They put a turbo on it with a custom exh manifold w/ Tial wg, some intake manifold mods and a custom front mount, but otherwise the engine is 100% bone stock. 84 lb inj and a simple low-end Aeromotive pump setup. We started the car for the 1st time Sat afternoon, he drove it to/from the track and raced it all day Sun without any misfiring or problems. Gotta love the FAST wb ecu
So it goes 118 mph already on its 2nd pass Sun at 17.5 psi boost, BUT it only put boost down for about 1/4-1/5th of the pass due to a mismatched turbo. It gained 32 mph from the 1/8th to the 1/4 markers once boost finally came up though ;-) Once it gets a better match and the boost cranked up I look for the car to run well over 130 mph in the 1/4 on turbo alone. Remember, this is a boneyard engine that hasn't even had the valvecover removed. The spray is installed and waiting after that
The car is alot of fun, easy to work on and relatively cheap to do. May have to build one myself someday
It's already being challenged Fri night by a high 10 sec/mid 120's turbo Miata for the title of fastest local import (other than all out, 150+ mph Supra of course
We're gonna paddle 'em ;-)
I bought a 4 channel Tek TDS224 DSO so was able to scope the Nissan position and ignition signals and all, and after minor rework we were able to set it all up with the stock distributor with built in ignition and position sensing systems. No add-on crank trigger or ignition system required. It did require a different interrupter wheel from an earlier model 240 to get the ref angle and rotor position relationship exactly right though, but it dropped right in. We used the generic harness supplied and removed the stock ecu and some of the factory harness. Hooked into the stock TPS, replaced the Nissan air and coolant temp sensors with GM and added the 3 bar MAP. Haven't verified yet, but the Nissan temp sensors may be close enough to the GM that it may have been unnecessary to replace 'em. Anyway, we also hooked into and used the existing stock low speed fan relay system to run the aftermarket electric fan, and are using the other high speed fan relay system to run the nitrous solenoid. Found both trigger lines in the p.s. kick panel so easy hookup to the FAST ecu. Cool!
I hope to specialize in custom installs. That scope has to get paid for somehow ;-)
TurboTR
TurboTR
