fifth gen brake conversion
Atl_monte
Has anybody tried using a set of 2012 SS Camaro Brembo brakes on a g-body? Just picked up a set and trying to put them to use
you can buy the brackets to bolt them to your modified spindles... or just mock everything up and make the brackets out of some 1/4" steel..
probably need at least 17", and maybe 18" wheels to clear.. but might be able to gain some room by taking those goofy round silver things off the top of the calipers..
Where can I get the brackets from? And those goofy round things are actually on the pad
You'll need 19's to clear them, at least that's what all Camaro and G8 brembo equipped cars have.
I'm quite familiar with the need for larger wheels the car already has an LS1 rear disc brake conversion and larger wheels
