Ok so I've been reading about frame offs and I want to make sure I'm doing this right. The bolts that are in the car they are covered. I have to use a whole saw to expose them?
Generally - the ones you will have the most trouble with are the three in the rear.
I made a template where the three cage nuts are located.
2 on passenger's side - one on the driver's side.
Without the template - it's pretty hard to gauge their location - because there is no real datum reference points inside the trunk to easily work from
Without the template - you can drill 2 really small holes in the bottom of truck to use as datum points to measure from - measure underneath - then transfer those locations to the interior to give you a ballpark location of the cage nuts.
The - You could - if you were so inclined - drill a small 1/4" hole and insert a PBblaster straw in there and soak from the top.
The others towards the front are also accessible from inside the car and you can do the same.
Those are pretty easy to measure and mark location, then drill a small hole from the top side of the body.
Afterwards, plug with a small body plug and sealant.
Whatever you do - try not to spin the cage nuts.
In other words - it it doesn't break loose with normal levels of torque - don't over do it.
They will spin.
Once you do - the fix to the body requires some specialized replacement parts, sheet metal cutting, and some welding. (If this happens - I can post you info on the parts and the links)
So if you have any doubt - soaking with PB blaster from the top is a very good choice.
The bottom as well just to help things.
Since you say you are doing a frame off - it is not hard to take out the seats and carpet - or they will be out anyway - giving you a straight shot access to the interior of the body.
Now if you are successful in getting them all out - then run a tap through the body cage nuts with a good penetrating oil.
Check the cage nuts to make sure they are still firmly welded into place.
If loose - repair with welder.
Likewise on the frame side - there are repair kits available for the frame holes.
Weld in washers basically
When putting the new body bolts back in - anti seize is the order of the day.
