What's the details of the upcoming turbo special. If things keep going good around here I would like to try pickin one up. With approval from my accountant/boss/activity planner/cook/housekeeper
Why have a pornstar when I can have all this
They will be on our site tomorrow to order on line or you can call in.
These units are a perfect solution as they deliver a high quality product for those on a budget. Well, after a
few weeks of discussion, the units have been priced and are available
for sale.
These will be available with
either a T3 4 bolt, T3 5 bolt, or Buick 3 bolt turbine housing.
Mitsubishi housings are NOT included in this offer. All units will
feature a 360* Race Bearing setup.
3231= recommended converter 2,400 stall HP rating is at 490 to the flywheel
3431=TE34 reccomended converter 2,600 stall Hp rating 545 to the flywheel
4431=TE44 recommended converter 2,700 stall HP rating is 580 to the flywheel
6031=TE60 recommended converter 2,800 stall HP rating is 600 to the flywheel
6076= recommended converter is a 3,200 stall Horsepower rating is 610 to
the flywheel
All of the entry level turbochargers come with an E-cover and a
cast back plate but include a 360 thrust bearing. These turbos usually come with the 270
thrust but are upgraded to the 360.
Normal retail is $921.99
NOW on sale for a limited time for $595.00
Add Heavy Duty actuators for $89.95
Oil Feed Line for $29.95
First 10 orders get a free GBP OIL DRAIN LINE!
