My car seems to run best at the recommended fuel pressure that the chip is burned for...
For whatever reason, it seems to go lean in high gear if I crank up the pressure. When I lowered the fuel pressure, the O2's balanced-out.
I suspect the problem may be too much baseline fuel pressure won't allow the pump to keep up with the boost curve at higher boost levels.
If your chip is burned for 25psi boost @ 68psi, then you need a 43psi baseline to maintain the fuel curve.
If you start out with 50psi fuel pressure and add 25psi boost to that, then the chip needs to see 75psi at the injectors to maintain the same curve.
If your pump will only give you 68-69psi, then you will be 6-7psi short, and go lean.
At least that's how I try to make sense of it.
If it were me, I'd try lowering the baseline fuel pressure to the chip maker's recommended setting, then try to add fuel in the chip if so equipped.
The added FMIC might have really made a difference in the fuel requirements.
I'd have a new chip burned if I were you...
TurboTweak Home
Erics chip put me straight into the tens...right out of the box.
