Something to think about in regards to pressure differential across the injector. It is not as black and white as you might think. Most especially when the injector pintle is seated. Think of of how much actual area of the pintle is seen by manifold pressure when the pintle is SEATED and how much hind end area of the pintle is seen on the fuel rail side when SEATED. This pressure differential variable would change as the size of the injector orifice changed from small injector capacity to large injector capacity. Just a theory of mine. What do you think? I could be off base on this.
