Don't like the indication I didn't talk to the boss first and "prematurly" posted this. I had communication with both Brian and Eric (see attached email below). I told Brian I would handle this with Eric in another email after I found out about Brian's loss and figured that he represented his company. Want to see that too??
You don't have all the information and facts about this Scot. I personally don't open my mouth unless I do. As you said in your own posting, "The issue here has been solved! why not let it pass...."
I don't need nor want any of your lessons on how things work. I've been in the automotive business for at least 22 years and have dealt with all of the 'previously known as' big three manufacturers plus numerous suppliers. Have tried to ignore you for the most part but your condesending attitude tells me all I and anyone else need to know about your business. Sounds like you think customers are all idiots.
THATS ALL... :smile:
Date: Saturday, May 30, 2009 8:03 AM
BWEAVY@aol.com
To:
asauve@chartermi.net
Subject: Re: headliner
I haven't ordered an ox gray in 5 years & that was drop shipped. Medium gray is all we stock which is the closest the factory sells.
I do not have any non illuminated plain mirrored units in stock.
Thanks,
Brian Weaver
GBodyParts.com
343 NC 42 West
Ahoskie NC 27910
(252) 332-8787
GBodyParts.com Online
Fax (252) 332-8087
In a message dated 5/30/2009 1:58:25 A.M. Eastern Daylight Time,
asauve@chartermi.net writes:
Brian,
I recently bought a headliner from you and want to make sure I have the correct color before I install it. I have an 86 T-type with the med gray interior (code 82) which should be the same as the GN. However, the headliner color is lighter than my original which is more of a blue-gray color. I recently ran across a color chart of the old GM interior colors and it shows the ox grey which is lighter when compared along side the med dark gray. So in other words I want to make sure I didn't receive the ox gray by accident. Are the colors listed on the headliner ABS board somewhere?
Also, have you had any issues with using the same thickness material on the moonroof slider board? Confirmed that GM originally used a thinner material on the slider and I don't want the new material to wear out prematurely because of increased interference.
One more. Do you carry the visors with the non-lighted passenger side vanity mirror? If so, how much for a recovered set?
