I am looking for someone to get my car dialed in and tuned. I live in Old Bridge NJ and need it done quickly,,, Everything is in but I want someone to fine tune the car who knows these cars inside and out..
please contact me ASAP..
Keith 7325893913
Here are the specs
Motor - Fully Built 109 with .020 over JE pistons, Pro-gram steel mains 2 center's, stock crank 10/20, stock rods all done, ARP main studs, SPS rod bolts, motor was balanced and is within a few grams on each cyl.
Dale Cherry ported and polished Irons, Bigger valves, Viton seals int and exhaust, de-shrouded around the valves. 100lb comp cams springs, Receiver grooved for 1007 felpro's These heads have not been flowed but were on a 10.0 car before I got them.
Hand ported intake manifold matched to the heads.
Modified front cover with a stock meling oil pump, setup for external oil cooler.
Comp cams 212/212 non-roller cam, degreed in.
60lb siemens injectors
Turbo is a 6776 BB
SMC Alky kit
Scanmaster2.0
Turbo tweak chip from Eric
Trans - Fully built 200r4 built by Otto in CT. Stage Ri ght Tr ansbrake, all the good internals, stock pan, alto red clutches, alto wideband, th200 servo, ect ect. Just gone through and replaced all the seals and cluches. No more than 5k on this. Also has a Vigalante 0 pump 3200 stall single disc too.
Terry Huston 3" DP with the cut out. Yes its stainless!!
Hooker Cat Back 2.5 with Magnaflow Stainless Muffler's
Driver - FAT, DUMB, UGLY
Keith 7325893913
Here are the specs
Turbo is a 6776 BB
SMC Alky kit
Scanmaster2.0
