Harness install questions
6 beats 8
LIVE BETTER...WORK UNION!
How is everyone mounting the SIDE harness straps to the floor(bolt in type). I got a bracket fabed up for the submarine belt. I just need some info on the side belts.
Thanks!
Ray
I put mine on the same bolts as the regular seat belts. I think I needed a T-50 torx bit for the bolt.
stock belt holes ,
i left the stock belts there as well , wouldnt want you to get a ticket for driving with no seat belt
I used the stock locations on the lap belts.
On the sub belt, I welded a 1/2" nut to a piece of 2.5" x 6"x 1/8" thick flat stock. Using a 1" holesaw, I cut a hole in the cross car brace that runs under the seat. I welded the flat stock to the brace with the nut inside the hole. Nice and strong.....not likely to fail
