frank_ster
- Feb 16, 2013
for instance a 1999 gtp the cooling fans rarely come on ! and my rad is near to that size.
i had a thin radiator same exact as this one but half the thickness and same exact results.The other issue is the grill size! Impreza's have pretty small grill openings. The electrician I work with had a built STI and that car had very little room with the 2.5 let alone a 3.8.
I would go with a thinner radiator to get more air flow through the radiator. If you are trying to pull air through an intercooler, condenser and a thick radiator you are fighting a losing battle. You need more air flow.
taking the trans cooler out of the radiator will give the radiator that many more BTU's to cool the engine.
Yes ceramic can help with under hood temps, yes you need a t-stat, or at least cut the guts out of one for some restriction. I have found RMI helps a few degrees but they all help. Do you have a fan shroud?
Your saying at idle it cools off more then driving which is kinda bass acwards for a engine with heat I issues.
^ its hard to say .. since this rad cools a 2.5 turbo 4 cylinder with zero issues before.
i know its not the same thing but how much heat could a 3.8 possibly make even at idle. over a 2.5 turbo.
nopeAre you running underdrive pulleys on the crank and / or water pump?
Given the 3.8 is 50% more displacement, is the heat +50%, also??? Given the orig rad was designed w/ cost concerns in mind, it would not be overkill, in it's original application.
" but i can force them on but it doesn't help."....That tells me that the rad is not capable of rejecting any more BTU's..
"yes the rad is not capable of rejecting any more btu's. what i'm trying to do is fix the root cause"
Sounds like you have answered your own question...
