- May 28, 2001
and if you read .. i dont have room!
I'm done reading................
driving it cools off.. idle it heats up.
yes i have tried gutted t stats also.
and the electric fans have shrouds
Post pics of the fan shroud
Bryan
mine doesn't leak oilthanks to the 3/4" breather it doesn't build crank case pressure.
but yea i had the wrap will probably switch to ceramic coating after.
http://www.summitracing.com/parts/flx-365/overview/
that and i have another fan because the rad is about 10" wider than those fans
who doesn't have a breather on their TR? lol . give it a few miles, the leaks are coming!
I meant installed on your car. A picture on a website doesn't help us trying to help you
Bryan
charlief1 has a good idea there - take the hood off and drive it as a test.
Cooling surface area at the radiator seems to have the largest impact on removing heat. Everything else seems to help 5% or less.
If the cooling air can only enter through a 1 square foot area and the radiator is 2 square feet...try to duct the cooling air best you can to the radiator.
Are you running the oem grille or an aftermarket mesh one? On the oe one the pieces that support the emblem and the emblem itself block about 50% of the already-small opening! also, since it's a GT are you still running the hood with the scoop on it? That might be contributing to the problem I described above with the "hood removed scenario". If so, I would try blocking that off, as counter-productive as that sounds, maybe a strip of duct tape to test the theory-
Removing the hood sounds like a good idea but will make the car overheat if its moving, ive done it... whwn I first put my engine in I left the hood off for the maiden voyage and thought it had an air bubble or something because the needle kept climbing. Its like the "tailgate open or closed" phenomenon in a pickup truck, all the air that wnters the engine compartment enters through the grill, is forced through the radiator and exits under the car. Removing the hood creates turbulence behind the radiator and wont allow air to flow thru it correctly. Its very important to seal around the radiator as mentioned above so all air that comes in must exit through the radiator.
Also, if your car runs hot even with no thermostat your radiator is not properly sized, all the insulating in the world wont make up for thos (and yes I read you dont have room for anything bigger). a better/larger radiator is not a band aid; adding header wrap etc to cover up an inadequate radiator is!
yes some people says that others say no. the headder wrap would cause the pipes them selves to get hotter. however it would also protect from thermal shock like splashes of water. and slow the cool down time to allow things to equalize.I recall reading that wrapping a header can lead to it being more prone to cracking..or is it the other way around?
