Hellacious squeal
Discussion in 'General Turbo Buick Tech' started by TOOMANYTOYS, Mar 6, 2017.
  1. TURBOELKY
    TURBOELKY
    Expand Collapse
    Jun 27, 2005
    3,126
    239
    Offline
    This is what I use. But I can't guarantee it's the length you need. But try and get a gatorback. Amazon is your best bet.
  2. earlbrown
    earlbrown
    Expand Collapse
    runs with scissors
    May 26, 2001
    5,750
    879
    Offline
    Pretty sure the Gatorbacks are no longer with us.
    I've got about 5 here from when I heard they were getting phased out.
    I miss the old old old Gatorbacks with the grooves on the smooth side (hence the name) that caused a whistle when running. I guess I was in the minority since now they changed over to bragging about how quiet they are. :)
  3. TURBOELKY
    TURBOELKY
    Expand Collapse
    Jun 27, 2005
    3,126
    239
    Offline
    You're right, they were phased out. However, continental makes one called the "continental poly V groove". Really quality belts.
  4. TurboTGuy
    TurboTGuy
    Expand Collapse
    Gray Beard Member
    Sep 24, 2010
    3,016
    783
    Online
  5. Heskahoka
    Heskahoka
    Expand Collapse
    Sep 10, 2012
    243
    44
    Offline
    Been there, had a constant squeak until car got really warmed up.
    Along with Turboelky above, I replaced my belt with the 1/2 inch shorter Continental Elite 4060635. (This was the one that cross-referenced to the Gatorback referenced in many earlier posts on the board.) Continental bought out Goodyear and the Poly V is the spiritual successor to the Gatorback.
    It took care of my squeak and was not too difficult to get on.
    • Agree Agree x 1
  6. TURBOELKY
    TURBOELKY
    Expand Collapse
    Jun 27, 2005
    3,126
    239
    Offline
    I have a feeling that amazon is about to sell out on these belts :D
    • Like Like x 1
  7. Ttype6
    Ttype6
    Expand Collapse
    Aug 17, 2004
    2,728
    143
    Online
    I stopped a squeal years ago on my Ttype by moving my crank pulley toward the front of the car by placing washers behind it for each of the bolt holes. There was a misalignment between the crank and water pump pulleys. GM used to sell a crank washer to accomplish this,so they did acknowledge the misalignment problem.
  8. TURBOELKY
    TURBOELKY
    Expand Collapse
    Jun 27, 2005
    3,126
    239
    Offline
    I have this issue because I didn't install the oil slinger...couldn't find it.
  9. earlbrown
    earlbrown
    Expand Collapse
    runs with scissors
    May 26, 2001
    5,750
    879
    Offline
    Every water pump I'm measured with a surface plate had the flange in the wrong place. On my current pump I had to pull it .069" to make it line up with the crank pulley.
  10. TURBOELKY
    TURBOELKY
    Expand Collapse
    Jun 27, 2005
    3,126
    239
    Offline
    I looked at my crank pulley this morning and realized it's pretty far off. Unless it's my water pump pulley is way forward but it lines up with the rest pretty good.
  11. haywire4130
    haywire4130
    Expand Collapse
    Sep 11, 2010
    588
    56
    Offline
    Post the part number of the belt youre currently running. If you got a dayco belt from autozone their listing is wrong for our cars and the belt is a half inch too long which will put the tensioner out of its effective range. A shorter belt will fix the problem. +2 on the gatorback belt, i keep a few spares just in case but since switching to the shorter goodyear belt i have had zero problems. I believe the part number ends in 635 (as mentioned above) instead of 640 which was the dayco (the last numbers are the length, 64" vs 63.5").
    • Agree Agree x 2
  12. TOOMANYTOYS
    TOOMANYTOYS
    Expand Collapse
    Oct 18, 2003
    97
    0
    Offline
    I just so happen to have bought a dayco belt from autozone. Got it when I picked up my water pump
  13. haywire4130
    haywire4130
    Expand Collapse
    Sep 11, 2010
    588
    56
    Offline
    There ya go! At least you caught it before it threw the belt and shredded a perfect hood liner... ask me how i know!
  14. TurboTGuy
    TurboTGuy
    Expand Collapse
    Gray Beard Member
    Sep 24, 2010
    3,016
    783
    Online
    Funny, I go deep into the 10's as often as I can with a Dayco 5060640 and have never had one spit or shred, though I do have aftermarket pulleys and a billet tensioner. The tensioner has only been on the car a couple of years, though and I've used the Dayco belts since I got the car in 2010.
Share This Page
