I have a TTA that I am working on and need to id the turbo. The compressor side has a 3" inlet and 2" outlet and is labeled Garrett AR 60 M24 L. It has a 6 bladed wheel.
Unfortunately, the turbo is installed and the downpipe is still attached, so I can't see the wheel. However, the exhaust side is a Precision housing and is labeled AR .63. I believe the center section is stamped 3/10?
These are all the pics I can get with it on the car. There is no engraving on the turbo outlet like in have seen on other units. Also, the stock heat shi I believe the car was put together in the early 2000's if that helps. I base that on the other parts on the car and statement from previous owners.
