Q Quigs Trained monkey Joined Aug 3, 2004 Aug 4, 2006 #1 I just made a MBC but I'm not quite sure what vac. lines to hook it up to. Thanks Phil
4 441120 4 Sale Joined Apr 18, 2005 Aug 4, 2006 #4 If it is a spring and check ball set up, spring end goes to the wastegate port and ball end goes to nipple on compressor housing. HTH
Q Quigs Trained monkey Joined Aug 3, 2004 Aug 5, 2006 #5 Thank you I first tried also connectting the wastegate selonoid with the rest of it and that didn't bleed of any boost. If I hit WTO it would have pulled over 20psi for sure. But now its good
4 441120 4 Sale Joined Apr 18, 2005 Aug 5, 2006 #6 Yea, my wastegate solenoid just holds the harness connector in place now :biggrin:
